Re: 70hp Evinrude setting up 10yrs
expect your carbs to be dirty and likely need rebuilding,not a hard job for anyone with some mechanical ability,if the boat has a built in gas tank,you want to empty it of old gas,you need to flush all gas lines with clean fuel,you will need to change the waterpump impeller and lowerunit gear oil,you might be able to fire it up not changing impeller ,but i dont suggest it because the rubber breaks and can be pushed into the waterways,i would also spray some fogging fluid into the cylinders in event its a bit stuck,the carbs and impeller are really the biggies for a motor that laid up,you can do a spark and compression test ,that will give some idea where the eng is ,of course you need spark gas and compression for it to run,but gas will be the problem because its the nature of the beast, a sitting eng will get a varnish buildup in the carbs especially for fuel was not run out or treated,but even gas treated can become trouble,you want a good battery,clean connections,i believe there is a topic on layed up engines,but if you do carbs and impeller,crnk it up see from there,be sure no bugs made nests in any waterpassages in lowrunit
