Re: Popping in and out of forward gear - 1978 35hp Evinrude
That popping out of gear is a symptom of a bad clutch dog in your gearcase. Before assuming the worst, check the shift lever and shift rod. Also if this is a remote setup, check your connection to the motor. It could need adjustment.
__________________
'77 Crestliner Voyager Dlx 16, '81 Johnson 25hp
post some pics of the gear and clutch dog ..the gear is pricey..my reverse was doing the same thing..I just replaced the clutch dog..will test tomorrow or monday..but it being the forward gear you may want to replace the gear and clutch dog. and make sure your shift cable is properly adjusted..also do not shift quickly from forward to reverse..always pause in between gears to allow prop to stop completely.
i just got a used gearcase for a friend for $150..but you never know what you are getting..you never mentioned the model of the motor..smaller HP motor can get by with a lot more than the bigger ones. Heres a pic of my clutch dog..its not a good one but you can see the extreme wear.
i have successfully cleaned up the gears,many people with some skill and no money did it,i used an air grinder,but i bet a dremel with some of the grinds they have these days weill work,make it nice and square just like the backsides,.most importantly,make sure your cables are adjusted so you get into gear without that grindind,and NO powershifts,that all works if YOU the mechanic use the boat,make sure anyone you lend or let drive listen to your instructions,definatly give it a shot,all you have is time and a bit of labor,
I took the lower unit off about 3 weeks ago to check the water pump...
I had to undo the linkage of course...
I am not certian it was seated and tight, and may not be engaging all the way...
I got in, got it all tight, and will try again...
I hung my little 3 hp Johnson on the back as a kick....
It is direct drive, and pull start.... Time to be very usefull!!!
If I continue to have problems, I will check the gears....
welding it up to the forward gear should work..but be careful to just spot weld it, and try to do it evenly, so it is not too out of balance. I would probably try that if the gears/clutch dog were already bad anyway. with a 35 I assume it is on a small boat, so reverse is not really needed.
Quote:
So I was just venting... But one never knows!
As stated above, if it is not fixed with the linkage, then I will machine them ...
Quote:
Originally Posted by Azonic
The manual shift is working...
I took off the inspection port, and looked at the rod and connector while shifting...
It does move in both directions and does not slip from what I can see...
So new clutch and gear? or just the clutch?
If it's like my old 18hp there should be 2 bolts on the connector. Get a socket in there and verify they're tight. I had the same problem. Ended up just tightening the bolts down good. I even put loctite on them. Mine was a '72 so I'm just taking a shot at this...
its not about being tight,its more about the slot in the shafts aligning with the screw,the screw does clamp it to a small extent ,but the design is so the shaft cant pull thru the connector if the screw does the job,its a very common mistake people make,not realizing the shaft isnt aligned ,often the screw while turned strips because it is running on side of shaft,then it strips the brass connector
in the case when you cant get the connector loose enough,the trickis,loosen both screws,then with a screwdirver or needle nosed pliers rotate the connector so you see the slot,then pry it just enough to to allow shaft to slip out,another tip,back when we would strip the screw or the connector,we would simply use a bolt and locknut,turning the connector 90 degrees so we could hold and tighten,i was young and no money
