Fixembones
- Aug 21, 2009
- 1
I recently purchased a used 1991 Bayliner Capri w/ a Force 90 HP. My best friend is a Boat Mechanic and everything checked out fine. It ran well for 2 months, and then the last 3-4 times the motor would barely crank and not turn over. I replaces the Battery and it seemed to work. I have another issue though. After the Motor Starts and turns over, it immediately stops and turns off. It does this like 5-6 times before I can get it running. Basically it starts and then clunks out. My friend says it is because it is old but I know there is a better explanantion. I was thinking Fuel Line or Pump? I am a total novice and have no clue. Spark Plugs?? what do you guys think?
