Re: How To Tell If My Yamaha Has An Alarm Horn?
while the yamaha V motors will alarm when cranked with the stop lanyard removed mot of the little engines wont. try it though.
if you still dont get an alarm leave the key on,locate the pink wire coming from the temp switch on the cyl head.
unplug it,jump from the engine harness side of that unpluged pink wire to ground and you should get a tone and a visual indicate.
