Need Help troubleshooting OMC King Cobra Sterndrive
plennon1
Sorry for the cross post. I realized i posted this in the wrong section.
I have a 1991 laser with a king cobra 460 and a king cobra OMC sterndrive. While boating on the river i had a prop strike at about 10mph. I immediately shut down the engine to chekc the damage. I saw that the prop (SS) showed signs of being hit...slight bend. There was a little smoke from engine compartment and a rubber like smell. I started the engine and engaged forward. The prop would spin but there was very little forward movement Reverse may a clunk noise and i did not try to move in reverse as i had to try to make it back to the dock. I was able to limp along to the dock..took about 10 minutes. The engine did not over heat.
Now I am wondering how do i troubleshoot the problem. I am very mechanical but i have limited experience with boats in this area. Rebuilding the sterndrive would not be a hard task for me. I want to try and pinpoint the problem before i start tearing into the sterndrive. I pulled the prop hoping there was a key...nope. I have searched the internet and came up with:
Gears striped in sterndrive
Broken Shaft in stern drive
shift cable out of adjustment
broken drive shaft
broken coupler at engine
Could someone point me in a direction to troubleshoot this?
Thanks for any help
PAt
billbayliner
Re: Need Help troubleshooting OMC King Cobra Sterndrive
Good Morning Pat:
Clue that it is coupler
Coupler again
Not to be an arse but there are few people around who have the tools, parts, and the know how to rebuild these drives.
I hope you can find the parts to repair but this is one of these worst combos, that being a 460 king Cobra, to find certain parts for.
If you can find the coupler........... Last I seen they were around the $500 range.
Bill
plennon1
Thanks....how could i verify that it is the coupler? IT is difficult to see behind the block. Can I remove the sterndrive to check it?? I understand that the engine will need to come out to replace it....that the only way?
I need to find a good picture of one...and hopefully it is still available if that is what it is.
I want to trya and verify the problem before i start tearing into anything.
Regarding rebuilding the sterndrive i was just making basic assumtions based on my 15yrs auto mech. experience rebuilding many auto and manual transmissions. I understand that special toosl may be required as well as manuals and such. Of course i have never done one so who knows.
Thank you for your help.
seattle2855
Seems like it would need to be a coupler or possibly a spun prop hub. But the rubber smell from the engine compartment definately suggests coupler.
Ayuh,.... The Diagnosis begins with Pulling the Drive....
