  #1
Old September 25th, 2009, 09:09 AM
DDorriety DDorriety is offline
Default Mercury 150hp Timing
Hello,
I plan to do a link and sync on my Mercury 150hp Saltwater series
ser#0T468962. It idles a little rough. I have various manuals but none exactly
match this motor. My question is:
1)The Decal on the motor states 4BTDC\20BTDC. Is the 20BTDC timing
Cranking Speed or Wide Open Throttle? Could someone please tell me the
Cranking Speed or Wide Open Throttle timing?
2)I understand that the final idling timing will be set by adjusting the idle RPM in gear in the water. How close to 4BTDC should I expect it to land.
Thanks,
Dennis
  #2
Old September 25th, 2009, 02:17 PM
Chris1956 Chris1956 is offline
Default Re: Mercury 150hp Timing
Dennis, If those specs are correct, they probably refer to idle pickup timing and max timing. Normally you set the carbs to just start to open when timing reaches the idle timing spec, in your case 4*BTDC. You set the max timing adjustment to keep max timing to 20*BTDC. Idle speed is set to 850-950RPM or so, whatever you can get away with.
You will find that max timing will be reached when the throttle is about 2/3 open.
BTW- You might recheck that idle pickup sped. My '93 150HP V6 has a 4*ADTC idle pickup spec.
  #3
Old September 25th, 2009, 03:02 PM
Thanks Chris,
I double checked the decal. It clearly states 4BTDC\20BTDC.
Do you know if the 20BTDC refers to WOT in the water or
could this be set on the trailer turning the starter?
Thanks,
Dennis
  #4
Old September 25th, 2009, 05:08 PM
j_martin j_martin is offline
Quote:
Originally Posted by DDorriety View Post
Thanks Chris,
Thanks,
Dennis
No, the spec is at full timing advance cranking. You actually have an advance module that will advance it a few more degrees at about 5000 rpm.
I'm thinking you have a foreign timing decal on it. 4BTDC sounds off quite a bit for either idle timing or throttle pickup. I would expect it to be about 8ATDC idle timing, and 4ATDC throttle pickup.
You should try to identify the engine more clearly and look up the timing specs for it. They do vary quite widely, especially at the idle end.
hope it helps
John
  #5
Old September 25th, 2009, 06:39 PM
Hello,
Thank you for your response.
The motor is a 2002 Mercury ser#0t468962 150XL
I did notice that the decal numbers 4BTDC\20BTDC is really close to
what in in the attached post.
http://forums.iboats.com/showthread.php?t=168855
Thanks for your help.
Dennis
  #6
Old September 26th, 2009, 09:58 AM
Dennis, I only have the specs for a '97 Merc 150. Do you have ADI or CDM ignition?
1997 Merc 150HP carb V6s with ADI Ignition systems have idle pickup timing of 2-9* ATDC, and max timing to be 21*BTDC. The CDM Ignition V6s vary more, with Max timing specs from 19-27* ATDC, depending on what ECU you have.
  #7
Old September 27th, 2009, 10:37 AM
Hello,
Thanks for the help.
My Motor has CDM ignition.
The control module is an 857185-A1.
I did the link and sync on the trailer. I used a dial indicator and verified the
timing pointer.
I set the idle timing to 4*ATDC and the max timing was at 20*BTDC so I left it alone. At least I think it was 20*BTDC. The 20 timing mark was aligned
with the pointer. I may need to verify if this was BTDC or ATDC.
You made me wonder when I saw your post.
Did you mean BTDC?
After doing link and sync on the trailer I backed the boat into the water
first I preformed the De-card procedure with Sea Foam then I
set the idle timing. I adjusted the idle timing to ~950 RPM out of gear and
~650 RPM in gear. I then checked the the idle timing it was at 0 degrees.
It sure did crank and idle much better.
I did not verify the Max timing. When I backed the boat into the water I was not sure it would be safe to run the RPM up with it on the trailer.The river I was at is not big enough to launch the boat. I thought I would check the
max timing next time I go to the lake.
Thanks,
Dennis
  #8
Old September 28th, 2009, 10:45 AM
sorry, I did mean BTDC for the max timing. I can check to see if I have a listing for your ECU. No promises, however
  #9
Old September 29th, 2009, 03:18 AM
Sorry, I do not have a spec for that ECU. Time for you to invest in a Merc Service Manual for your motor.
  #10
Old September 29th, 2009, 07:17 AM
Thanks Chris for your help.
I've ordered a manual that I think may cover this motor.
I'll let you know how it turns out.
Dennis
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Any diagrams of timing screws or advance/retard module(mercury xr4/150hp) xxturbowesxx Mercury & Mariner Outboards 3 August 22nd, 2009 01:39 PM
timing tape 79 merc 150hp BENGLER Mercury & Mariner Outboards 1 July 1st, 2008 07:28 PM
Mercury 1500 150HP Timing and synchronizing Davidjoy Mercury & Mariner Outboards 6 January 23rd, 2008 10:03 AM
timing a 1986 150hp evinrude super v bigt70 Johnson & Evinrude Outboards 0 June 27th, 2007 07:13 PM
Timing Specs 150hp Black Max DavoOZ Mercury & Mariner Outboards 2 December 6th, 2004 08:21 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
