Okay, I am starting on replacing the dog clutch and forward gear, I have the REAL shop manual, and am having trouble before even taking off the lower unit
First, I could not believe how loose the prop was on. The only thing holding the nut on was the cotter pin, as I could spin it with my pinky..... no kidding. Then the prop had a play of at least 1/4" forward/back. I don't know what is normal, but this seemed excessive.
Well, I removed all seven bolts and the lower unit starts to drop, but will not come off the midsection? I took the pin out of the shift lever. The manual said to push the shift lever toward the power head, so I moved the easiest part of the shift lever (what the cable connected to) and pushed it all the way back toward the spark plug area.
I don't know if the driveshaft is not coming out, or if it is the shift rod. It says to not bend the shift rod, so I don't want to pry too hard, but don't know what to do.
I also have no idea what good it does to remove the shift lever pin, as I do not see how it releases the shift rod?
Can anyone clue me in? I don't want to damage anything!
