I have a 120 hp Force on a pontoon. I just got this motor to replace my old Force 90. Replaced impeller, thermostat and temp sensor before taking it out. Motor starts easily and runs great but the water pressure seems low especially at idle. I went through a dead slow zone and the horn went off. I increased the RPMs and the pressure went up and horn off. Running about 10-12 lbs at 3500 RPMs and falls to 0-2 lbs at idle. Does it every time. I've checked the tube seal and water passages and they all seem OK. Any suggestions? Could I have put the impeller in backward?
