  #1
Old April 15th, 2003, 03:07 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Larger tires on pontoon trailer???
Hey GuysMy pontoon boat, with a single axle trailer, currently has the small 10" tires(20.5-8.0-10). My question is, what affect would going up to a 13" rim and tire have on towing? I realize that launching may be a little different(No Problem), but I am wondering if it would make it easier to tow and how it might affect handling. Any comments would be appreciated.
__________________
Rick
"Boating is Life...All the rest is just Details"
  #2
Old April 15th, 2003, 05:16 PM
JB's Avatar
JB JB is offline
Default Re: Larger tires on pontoon trailer???
Hi, Rick.I made the change from those baloons to 175X13s on my trailer a couple of years ago.It's hard to say what other effects it may have had, but my highway towing mileage jumped from around 13 to around 15-16mpg.I have found no difference in launching/loading on hard ramps but have not tried launching at unimproved sites.
__________________
RED SKY at night. . .
JB
  #3
Old April 15th, 2003, 05:25 PM
6MISFITZ 6MISFITZ is offline
It would raise the ceter of gravity a little which might be felt a little more in cross winds and you will have to submerge the trailer a little further to load or float the boat. It might be just a little more tippy in the corners too but as long as you slow down for curves, I do not see a down side. While the wheels are off the ground, chech the run out on the bearings by moving the drum/hub up & down or side to side (just a small deflection is O.K.) and spin the hub to make sure it turns free.Mike.
  #4
Old April 15th, 2003, 06:07 PM
Thanks JB And Mike. That's what I was lookin' for. The mileage deal(With a F-150) and pulling ease is really what I was after. I plan on pulling farther than usual this year(About 350 Miles one way) to seek out new boating areas, so mileage is important. I figured the center of gravity will be a bit higher, but being mostly highway where I'm going, that shouldn't present a big problem. I check the bearings often, so they should be fine. Thanks for your comments and suggestions. I'm going to try out the 13" tires and see how she does.
__________________
Rick
  #5
Old April 15th, 2003, 08:16 PM
howster howster is offline
i work on tires for a livin you should make the change way better on your bearings (dont forget to check those)go with the st series or lt this will make it posible to put at least 50 psi always go 5 pounds under max inflation youll gain that much in road heat...THE HOWSTER
  #6
Old April 16th, 2003, 04:49 AM
Thanks HowsterWill look into the ST series tires.
__________________
Rick
  #7
Old April 17th, 2003, 07:28 AM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Make Sure you've got the Clearance for the Taller Tires....Be a Shame to rub a Hole in your Pontoons....
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #8
Old April 17th, 2003, 08:15 AM
Thanks Bondo, Plenty of clearence, once I get the fenders off. I'm still working on how to reattach the fenders after I get the tires on there. Any suggestions???
__________________
Rick
  #9
Old April 17th, 2003, 09:43 PM
Bond-o's Avatar
Master Shipwright
Are the fenders Welded to the sub-frame ??? Cut them off,+ weld em back on higher...If not, Clamp them to the top of the tube...
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Larger Trailer Wheels and abnormal wear Johnshan1 Trailers and Towing 3 August 16th, 2004 06:46 PM
Trailer Tires Johnnielund Trailers and Towing 2 April 27th, 2004 07:01 AM
trailer tires vs automobile tires manitoba1 Trailers and Towing 16 July 29th, 2003 01:54 PM
Right Size Tires to replace my E78-14 Trailer Tires? shade788 Trailers and Towing 4 May 22nd, 2003 05:55 PM
Trailer tires not just car tires? MarkC Trailers and Towing 4 July 19th, 2001 09:23 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
