fishbasket
- Aug 6, 2009
- 5
does anyone out there have the diagram (or can you email me) from the original owners manual on how to install the bottom part of the shift solenoid into the (i believe its the oil pump) is there something that holds the bottom of the shift solenoid in place>
i had a 70' hydro electric lower unit johnson 60hp with stripped gears and dog. 60esl70b
i replaced lower unit with 69' evinrude hydro electric 55hp 55973a
it was shifting fine with 60hp lower unit f/n/r but thunking due to worn gears and dog
now with the 69' evinrue lower end on, its stuck in forward
i put the shift solenoid assembly from the 70' in the 69' gearcase
but im not sure how the bottom of the assembly goes in. do i have to take out the oil pump does it attach to the back of the oil pump behind the forward gear>>? please help
still frustrated
fishbasket
still frustrated
fishbasket
