Quote:
Originally Posted by crxess
Specifically...What is the Shallow drive and how/when do you use it?
Exactly what it says, it is for running in shallow water. Tilt the motor up, flip the shallow water thing down, and let the motor down against it. It holds the motor partially tilted so your prop doesn't dredge a new channel. It is for slow speed only. Does it work??? Sort of. So does a push pole.
