Re: 1996 evinrude 15 hp impeller problem
An easy remedy is to buy the complete pump kit, with the stainless steel plate, cup, plastic housing, seals and impeller w/ key. If the plate, or cup are scored, they will eat up a new inpeller in short order. Also, the kit has grease to lube the impeller and cup for assembly, use it liberally when putting the pump back together.
