I've been told that while my boat motor is hot, but not running, the source of dripping gas (causing flooding) into my carb throat through the 2 tubes/jets (coming from the float bowl?) is either the needle not seating or the float set too high. If it's the float too high, does that mean I need to bend it down so that it floats sooner/lower in the bowl, causing the needle to rise/open when the bowl is less full? OR, is it the other way around since it's like a teeter/totter - when it floats, it closes? I did NOT replace the float when I rebuilt the carb - was not a part of the kit. If the float is leaking, would that cause it not to float, leaving the needle valve open and the gas level in the bowl to get too high? I inspected the float closely when rebuilding the carb, and it appeared perfect. If it has been filling, would I be able to tell that if I remove it after running the boat for a while? Any advice would be much appreciated!!
