  #1
Old September 22nd, 2009, 04:02 PM
JamesMc JamesMc is offline
Default Yamaha 2004, 60 hp, 704 remote control
Trying to find the Netural safty switch on the 704 control. Found two brown wires but don't know where they go or their function. Then there are a number of colored wires, two different connectors all coming out of the bottom of the 704 housing.
If I jump the solenoid the engine runs good. But just turning the key get no response. It does have the push choke ign. switch. Thanks for any help. Jim
  #2
Old September 22nd, 2009, 07:20 PM
rodbolt rodbolt is offline
Default Re: Yamaha 2004, 60 hp, 704 remote control
the two brown wires exiting the 704 are for Nuetral start. should have continuity between the in N.
  #3
Old September 26th, 2009, 11:12 PM
Can't find the neutral safety switch. The housing on the 704 is quite long with a few side plates but have yet to find the switch. Wondered if jumping the two brown wires(from the switch) will let the engine start. Jumping the solenoid all the time is a pain. Thanks, Jim
  #4
Old September 27th, 2009, 09:14 AM
switch is inside the box,thats why the brown wires exit it.
box must be partially dissasembled and the black plastic cover removed for access.
  #5
Old October 18th, 2009, 04:32 PM
Thanks for your answer. I have removed the 704 box and found the neutral safety switch but there is no power going to the switch, no mater what position the ignition/start switch is in?? Starting to check for continunity between the engine wires and the control console etc. Any ideas would be appreciated. Thanks again, Jim
  #6
Old October 19th, 2009, 12:18 AM
blackbox blackbox is offline
do you have power at the red power feed wire? is the fuse at the motor blowen (20 amp)?
  #7
Old October 26th, 2009, 01:17 PM
Hi again, Yes the red power wire is hot and the fuse is good at the engine. I don't have an engine wiring diagram for this 2004 Yamaha 60 hp, model: 60TLRC .
Do not have power at the Brown wire (neutral safety switch) in the shift 704 remote control. Battery (Neg)has two small wires going into the boat and the (Pos) has one red stripped wire going into the boat.
Ignition switch has no effect, only way to start engine is to leave the key in the "on" position and jump the solenoid, engine starts and runs fine.
Thanks for any help, Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
yamaha 703 remote control goingagain Yamaha & Suzuki Outboards 3 March 11th, 2007 08:49 PM
Value on a 2004 50 hp 2 stroke Yamaha remote masquinongy Yamaha & Suzuki Outboards 3 December 17th, 2004 06:12 PM
Yamaha Remote Control Box a05vma2 Yamaha & Suzuki Outboards 2 May 26th, 2004 01:21 PM
2004 Yamaha FS25ES Tiller to remote Stephengw Non-Repair Outboard Discussions 1 August 17th, 2003 12:34 PM
2004 Yamaha FS25ES Tiller to remote Stephengw Yamaha & Suzuki Outboards 1 August 17th, 2003 12:34 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
