Re: 64 9.5 lower unit bearing housing removal
I think you'll be just fine, as mine didn't have any sealer on it at all, and never leaked. I'm pretty sure the little ridges on the mating surface of the housing seal it all up pretty well, and your 3M sealer is just a bit of insurance. Does your driveshaft have a worn spot from the old seal?? Mine does, but the new seal sits slightly higher on the shaft so it is tight to the driveshaft.....I was thinking I might have to build up the shaft then mill it back to the proper diameter. Fortunately it doesn't look like that'll be necessary. Hope it all works out for you
