I have a Merc 165 drive on my Glasply. The boat sat in the water after a dinged prop for a year, never moved. It was finally towed to the launch when a trailer was aquired.
Its my grandpa's old boat. The lower end fluid hadn't been changed in 3+ years. Today, I drained the fluid.
When I first pulled the plug, about 3-5 bottle caps (maybe 1-2 ounces at most) full of clear water came out. After the water drained out, VERY black fluid followed it. The oil did not seem to be mixed with the water at all. If it has sat for a long time with a little water in the outdrive, would the water and oil seperate?
I don't believe the drive was run with water in it. I figure from sitting inop in the water for a year, some water is going to seep in (but im probably wrong).
The drive worked well before sitting.
Am I screwed? Should I just order a new drive? The fluid was BLACK as can be. The water was clear as can be.
Am I worried over nothing? Thanks for any help.
