NEED Help Please
ecom2b
I have an older Starcraft boat with a 351 WINDSOR motor with an OMC drive could you tell me what v6 motor I could replace that motor with as mine had been blown, and everywhere I call for another 351 they want like $2500 just for a block, any assistance would be great.
Thank you
Louie
TowRoper
Re: NEED Help Please
we need a little more info like how long is the boat, is it fiberglass or alum, what model out drive.
ecom2b
sorry the boat is a 21' fiberglass. with an omc drive
thank you
Louie
cr2k
OMC stringer or Cobra? Year of boat would be a big help here.
You would be better off with a v-8 near your original HP. If you go to a v-6 you may need to change the gears in your drive to a lower ratio. At a minimum you would have to change to a lower pitch prop.
haulnazz15
if you go to ebay, you can find tons of 351w rebuild marine long blocks for $1300-1400. Rapido marine is usually highly touted on this site, I got mine from a seller named rmalaga who is with A&L Engine. No point in going to a V6 when you can get a perfectly good 351w to replace it with minimal headache.
jfw432
I know this is an older thread but in case anyone does a search or the OP never found a solution... The 351 Windsor engines are just 5.8L Ford engine available in a variety of trucks in the mid/late 80's to early 90's. You could probably pick up a long block from a nearby junkyard for a few hundred dollars. You will obviously have to swap a bunch of car specific off and boat specific stuff on but it's a very cost effective solution if necessary.
