  #1
Old September 21st, 2009, 01:19 AM
matthysone matthysone is offline
Default 75' Evinrude 85 hp stuck in reverse *SOLVED*
While waiting to get out of the water at the ramp and with no noise or other warning, my 85 hp rude stuck in reverse, had very limited movement in the control unit as well. It was embarrassing to paddle to a busy ramp. Upon inspection I determined the shift rod, the one from the power head to the LU, was stuck. I did this by disconnecting the linkage on the opposite side of the lever that is connected to the shift rod, couldn't get any movement. However, now I had full movement of the control unit.
Anyone with some insight on this issue would be much appreciated.
Last edited by matthysone : October 12th, 2009 at 02:59 AM. Reason: problem solved
  #2
Old September 21st, 2009, 06:38 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 75' Evinrude 85 hp stuck in reverse
that motor has the bell crank linkage. the older motors are bad about the shift rod seal going bad, and the shift rod rusting going into the lower unit. then they become hard to move. i had one in the shop, that had so much rust on it, we could not force it into reverse.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old September 21st, 2009, 11:46 AM
I will inspect the seal and rust. The rust issue seems more likely after being stored for the season or a gradual problem. This occurred suddenly. The shifting was fine just minutes before.
If the shift rod seal goes bad, water can get into the LU oil I assume. Yes?
  #4
Old September 21st, 2009, 12:50 PM
yes.
__________________
FLORIDA GATORS
TEBOW Country
  #5
Old September 21st, 2009, 01:29 PM
ezeke ezeke is offline
1973 - 1977 V4 85HP recreational motors have a gearcase with hydraulic assist; they requires that the gearcase be properly filled with high viscosity marine gear oil in order to function.
  #6
Old September 24th, 2009, 07:05 PM
I've dropped the lower unit and removed the shift solenoid cover and shift rod. The hydraulic assist is here connected to the push rod assy. What should I be able to tell from here? I know it's hyd assist but I can not push the push rod assy down at all and thats while turning the prop shaft. Do I need to tear down the gearcase. The push rod is up and stuck in reverse.
Thanks
  #7
Old September 24th, 2009, 09:50 PM
Try turning the driveshaft instead. Make sure that the gearcase is filled with oil first.
  #8
Old October 12th, 2009, 02:58 AM
Default Re: 75' Evinrude 85 hp stuck in reverse *SOLVED*
Here's the follow up. I tore down the LU and found several damaged parts including the forward gear, the back side of this gear has four teeth that engage and drive the hydraulic pump. The pic shows where the teeth used to be. Also in the pic is a part of the hydraulic pump that normally rides inside the front gear in the hollow where the four broken teeth are.
I think this may have been broken for sometime and some piece of metal finally lodged causing the unit to be stuck in reverse. The price for parts new or used are to high, however, since I think this has been broken for awhile I plan to remove certain parts which will disable the hydraulic pump and the hyd. assist shifting feature. I should then still be able to shift.
Okay, I reassembled on the bench and I can still shift by pushing/pulling on the shift rod. I'll see how it works on the water. Anyone have any thoughts on whether the LU can reliably be used in this altered state?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1985 evinrude stuck in reverse mpd145 Johnson & Evinrude Outboards 2 September 11th, 2007 01:30 PM
1977 evinrude 35 hp stuck in reverse ona mission Johnson & Evinrude Outboards 2 July 27th, 2006 09:42 PM
67 Evinrude Johnson 33hp stuck in reverse cangolden Johnson & Evinrude Outboards 4 October 24th, 2003 11:36 AM
Evinrude 35 HP stuck in reverse blindwillsee Non-Repair Outboard Discussions 1 August 22nd, 2003 12:31 AM
Evinrude 90hp stuck in reverse Bearded Lady Johnson & Evinrude Outboards 5 July 8th, 2002 08:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
