I have a 1988 GM 350 inboard marinized by Mercruiser. I changed the spark plugs and mechanical fuel pump and now it won't idle. When I run at 1500-1800 rpms it smokes and there is fuel and carbon in the exhaust water. I adjusted the idle screws on the carb to a half turn out and it idled better. Factory spec. for the idle screws is two turns out. I am confident the spark plug change is not the problem and the mechanic who recently rebuilt the carb checked it out and found no problem. The dealer stated the fuel pump he sold me is the same one used regularly (QuickSilver). Any ideas what went wrong? Tomorrow I am putting the carb back on to try again. Should I put the old fuel pump back on? This all started when the boat would not come up to full power and I did a tune up, carb rebuild, fuel pump replacement. Now I've got this new problem.
