  #1
Old September 20th, 2009, 05:19 PM
fishrdan fishrdan is offline
Default bronze thru-hull fitting on painted aluminum boat
Is a bronze thru-hull fitting going to cause any problems on a painted aluminum hull, (galvanic corrosion)?
I need to replace the livewell drain thru-hull fitting on my project boat and wanted something more sturdy than the original plastic fitting, IE: if this fitting were to fail it could sink the boat. I'm under the impression the manufacturer used plastic fittings because are were less expensive, but unsure if they did it to avoid corrosion problems between dissimilar metals. The bronze fitting won't be in contact with aluminum since the aluminum is painted and I'll be sealing it with 3M 5200.
My main concern is to avoid galvanic corrosion. I just sanded/painted the edge of the transom getting rid of crevice corrosion along the corner of the transom-hull and don't want to invite another problem.
__________________
2001 Crestliner SuperHawk 1800, Mercruiser 140HP,,, rebuild in progress
2007 Tracker 1436 jon boat, 7.5HP Force
  #2
Old September 20th, 2009, 05:26 PM
dingbat's Avatar
dingbat dingbat is offline
Default Re: bronze thru-hull fitting on painted aluminum boat
Any time you have dissimilar metals even in proximity of each other there are bound to be problems.
Don't confuse the cheap PVC thru hulls with some of the better composite materials. I would use a Marelon fitting and not worry about it.
__________________
Grady White Seafarer
200 Evinrude Ocean Pro
  #3
Old September 20th, 2009, 05:52 PM
Thanks dingbat, those Marelon fittings sound stronger (glass reinforced) than the original nylon fitting that was on there. I'll have to get one of those for peace of mind on strength and corrosion.
Since you brought up PVC, I think my concern for this fitting shouldn't really be an issue since the livewell pump is made out of PVC and if anything is going to easily snap off, it's going to be the thru-hull pump and not the thru-hull drain.
__________________
  #4
Old September 21st, 2009, 02:06 PM
Ned L's Avatar
Ned L Ned L is offline
Not to change your direction at all, but as an FYI, all that is needed to properly use a bronze through hull on aluminum would be isolation washers, could be as basic as disks cut from a plastic milk jug. (you are onto the right idea thinking that the aluminum is painted, but in reality the paint would probably get scratched through during tightning. Likewise, 5200 would also allow metal to metal at some spot.)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
where to buy bronze thru-hull fittings? roozter2550 Boat Topics and Questions (not engine topics) 2 May 19th, 2009 10:19 PM
1992 Aluminum Boat needs a good cleaning of the Aluminum Hull What works best?? sigarmsp226 Boat Topics and Questions (not engine topics) 10 December 15th, 2007 07:35 AM
just painted my aluminum boat, now what? phatmanmike Boat Topics and Questions (not engine topics) 10 March 15th, 2004 07:14 PM
Aluminum vs. Bronze props John Reynolds Mercury & Mariner Outboards 3 May 6th, 2003 03:33 PM
Pro/con aluminum vs. bronze or brass props... markjewell Johnson & Evinrude Outboards 3 September 27th, 2002 05:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
