Re: 19 foot aluminum with a bent hull
it is not an exact science...
your trick is to support the floor where it is flat and good..
and then add pressure in the center of the worst bow, from the inside of the boat..in a controled manner..
like if you were in the opening of a strongly framed garage door.. and you put some type of jacking device between the frame of the door and the inside of the boat(floor)...you have to have a broad contact , other wise youd put a little dent in your big bowed area!!!
the pattern of your ribbing will play a roll in how you attack this problem
like a 2X2 piece of thick ply wood under your jacking device..
and remember, this is only how Id try it...not that it is a professional way!!!
and reset your trailer if the hull isnt supported properly!!!
bob
