Re: Leaking copper pipes on AQ130
Man - does this bring back memories!. I had exactly the same thing happen with my AQ130 in my old Glastron. Great engine by the way! I ended up getting a friend to help me and the remedy was VERY simple. First, I assume you got all the rings / gaskets from Volvo. You must as generics will NOT work. Assuming this is the case, here is the fix. I thought I had everything properly seated. I did not. I was afraid I would break something if I forced the copper any further. Don't be afraid. You have to really drive those tubes into the holes. My friend did it and I was already thinking how I was going to politely tell him he owed me for the copper pipes, etc, that I just KNEW he broke. I cringed and let him continue. Bottom line - it worked and they didnt leak a drop! All fixed for as long as I had the boat. DONT BE AFRAID!
