  #1
Old September 19th, 2009, 10:13 PM
ftlee20723 ftlee20723 is offline
Default Trophy Boat Owners - Need Your Help Quickly
I picked up a new (08) Trophy 2206 Dual-Console today. I took it on a 2-Hour ride and when I arrived back at my marina and pulled the drain plug out there was A LOT of water in the bildge.
The owner's manual supplement states that:
Quote:
Depending on the type of boat you have, you may have underwater fittings that need drain plugs. Garboard drain plugs and fishbox drain plugs need to be in place before the boat goes into the water. Any fitting that will be underwater needs to be plugged or the seacock needs to be closed.
Are there supposed to be drain plugs in:
1. Port Cockpit Drain?
2. Aft Livewell Drain?
3. Garboard Drain (Yes)
4. Starboard Cockpit Drain?
5. Utility Center Sink Drain?
6. Starboard Forward Fishbox Drain?
7. Port Forward Fishbox Drain?
Where do the drain plugs go? On the outside of the boat or, in the fishbox itself? I'm pretty sure I saw a bag of plugs on the boat but, I don't know where they go.
And last, where is the seacock for the livewell?
Thanks,
Frank
  #2
Old September 21st, 2009, 04:52 PM
kawiski kawiski is offline
Default Re: Trophy Boat Owners - Need Your Help Quickly
What does your selling dealer say if you bought it from a dealer?
  #3
Old September 25th, 2009, 08:48 PM
Ghost Chaser Ghost Chaser is offline
Nice boat but newer than what most of have. Sounds unusual to have so many plugs but than again it is a dual console. If you saw a bag of plugs, they should have a purpose. How much water would you say was in the bilge? Is the boat a pro or are some of those areas that provide plugs optional? Did you put the plug in prior to launch or was it already on, if so rain may have made it into the bilge.
check the seal on the rear hatch access.They have been known to leak.
did you take water over the bow during your run? do you have pumps at the fish boxes or just holes?
I would have the dealer re-do your delivery walkthrough and go over the boat in detail.
Don't be alarmed, ther should be a reason for the water entry. Good luck and let me know what happens.
EdF
2003 2002 135 optimax
  #4
Old September 28th, 2009, 04:24 PM
lyle's Avatar
lyle lyle is offline
welcome to the world of trophy
__________________
  #5
Old September 28th, 2009, 04:36 PM
Huron Angler's Avatar
Huron Angler Huron Angler is offline
Send a message via MSN to Huron Angler
Those plugs should be in place in all fish wells, coolers, dry storage or any other storage that has a hole in the bottom(on the inside...not the outside of the hull). My dad's 2001 Seaswirl Striper is pretty similar to the Trophy and he had the same predicament.
If you don't keep those plugs in...then water will enter those cargo holds when the boat rocks back and forth since the design allows that for drainage, and sit in there until it is mopped up or evaporates.
These drains allow ice to melt and the water flows into the lake/ocean by gravity as these hulls are partially self-bailing usually. If used properly they are great and make clean-up a breeze with the raw water washdown.
I usually prop the hatches open to air dry after cleaning so mildew/mold doesn't build up in there and stink up the boat. If you want to use one as dry storage just don't ever take the plug out and it will stay dry 100% of the time.
__________________
1979 16' Starcraft SuperSport w/ '70 80hp Mercury
1960s 12' AeroCraft w/ '55 5.5hp Johnson
"The gods do not deduct from man's allotted span the hours spent in fishing"
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2001 17' Trophy boat Page2009 Boat Topics and Questions (not engine topics) 1 July 22nd, 2009 09:21 AM
1998 Trophy Boat: vanncarla Boat Topics and Questions (not engine topics) 2 March 2nd, 2009 02:50 AM
no trophy owners Link2052 Trophy Boats 33 November 5th, 2008 08:31 AM
Questions for owners of newer Trophy boats. The Famous Grouse Boat Topics and Questions (not engine topics) 4 September 29th, 2008 01:14 PM
91 Force 150 Trophy boat Bradforce Force & Chrysler Outboards 2 July 14th, 2006 11:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
