I have a 35HP mercury outboard that has been out of the water for a couple years. Installed new plugs, water pump and cleaned the wiring and it fired right up.
Problem: Where the top spark plug screws into the head, there is a steady stream of water pouring out. Water is still flowing through the tell tale and the engine seems to run fine. Took it out for a test and it ran for 4 hours with no issues. I assume it wouldn't run if water was filling the cylinder and am wondering if the outside of a water jacket could have been cracked by over tightening the spark plug???
Thanks in advance for any insight.
