The first time I drained my LU oil it was very milky, almost the color of pure milk. I changed it and went out for a day of boating and let the boat sit in the driveway for 5 days after my trip to allow it to settle and drained the oil. The oil was still a bit milky, but not as bad. Kind of like the color of coffee with a little cream in it. I'm not sure if I should be worried or not. From what I understand a small amount of water intrusion should be expected? I have not pressure tested the unit, but when I cracked the vent plug loose you could hear air escape, kind of like opening a pop bottle but not quite as pronounced. Should I be worried or just replace the drain/fill, level, and vent plug seals and refill and call it good? Thanks.
