I put this boat in the water about a weekago , Fired up at home no problems;
we put it the water, cranked up fine to launch off the trailer...
I turned it off to get other gear, minutes later I turn the key;saw and heard a spark at the positive side of the battery and nothing happen, Now all I get is a clicking sound from the fuel pump, put nothing else...
I checked the main fuse in the red capsule, but it was good changed it any way. I ran a jumper between the start solenoid and the starter does turn,
I also dismantled the throttle assembly in order to get to the neutral start switch; it was good and jump passed it and still nothing......
I'm sure it is something small that I am over looking
