  #1
Old September 19th, 2009, 10:08 AM
Starman Starman is offline
Default 18' Lund with 90 HP Yamaha???
I'm looking at a 18' Lund with a 90 HP Yamaha 4 stroke. The owner says it will do 35 with two people. Seems a 90 is two small for this boat. I like the boat, but not sure about the 90 Yamaha. Would like to have a boat that would run closer to 40 at Wot. Could putting another prop on it get the top speed to 40?
  #2
Old September 20th, 2009, 12:27 PM
MT Bob's Avatar
MT Bob MT Bob is offline
Default Re: 18' Lund with 90 HP Yamaha???
I have a 1700 Fisherman with a 115 Merc. With 2 people it will top out at about 38-40 MPH with full tank of gas & fishing equipment. I mostly run it at about 75% throttle and cruise at around 30 MPH to conserve fuel.
I'd say the 90 HP on an 18 ft. boat is a bit under powered. Changing the prop may help, but I'd try it first.
__________________
Montana Bob
"Too Many Lakes, Too Little Time"
Lund 1700 Fisherman, 2002
115 Merc EFI 2002
9.9 Merc 4 stroke 2000
  #3
Old September 21st, 2009, 04:36 PM
ziemann's Avatar
ziemann ziemann is offline
When you prop an outboard, your goal is to keep the engine within the center of it's peak power band (i.e. recommended peak RPM). You can fine tune your prop & pitch to gain your peak RPM and may be able to fine tune by experimenting with different props, engine height, and proper trim to pull every last ounce of performance out of that motor. Maybe, just maybe, you can get close to 40...but I seriously doubt it....
I have run 2 different motors on Lund Mr. Pike 17's. That boat is a 93" beam and 17' 2" long. With 32 gallons of fuel on board:
2005 Johnson 90 (2 stroke 60 degree looper)- I was able to get 37.8 MPH with average load and weight distribution in the second hole. I was running a Solace aluminum 13.5x15 prop @ 5700 RPM's. That particular Johnson was known as a real power house for a 2 stroke because if was a V-4.
2008 Evinrude 90 E-tec- I am able to get 34.8 MPH with average load and weight distribution also in the second hole. I am running a BRP aluminum 13.5x15 prop @ 5300 RPM's.
My point is that you have a bit bigger boat and a 4 stroke that will probably provide similar performance to my outboards. I think you are going to be hard pressed to hit 40 MPH. Maybe with a good stainless prop.....
  #4
Old September 22nd, 2009, 01:38 PM
cranksbait cranksbait is offline
Depending on what boat you have that could very well be the proper engine size. Especially if it is a tiller model. If you are able to get 35 with two people, you should be able to get close to the 40 mark solo. I know I lost 5 mph when I repropped but now I am running the right rpm and will make my motor last longer.
  #5
Old September 26th, 2009, 10:49 PM
ut84088 ut84088 is offline
35-38 seems about right to me. I have a 17 foot Explorer with a 75HP ficht and I can get 32-34 at 5200-5400 RPM with 2-4 people. I've thought about going to the 90hp for a slightly better hole shot, but I think I would only gain a few mph.
  #6
Old October 31st, 2009, 01:25 PM
JJS1 JJS1 is offline
I have a 17' (17', 3") 1775 Classic Sport with a 90 Merc 4-stroke and it quickly gets up to 38, 39 - I'm still breaking it in and have only opened it up in short bursts so I'm not sure if that's all it'll do or not, but I'd say it's just about max'd out at that speed.
  #7
Old November 4th, 2009, 06:58 PM
Woodrow246's Avatar
Woodrow246 Woodrow246 is offline
3 guys all the gear for saltwater crab pots etc....i can maintain 35 if the water is right the fine tuning the trim has a large impact on top speed as well. My 80hp Yammy pushes the boat well and is great on fuel. I would love a 115, but couldnt be happier with my setup for mileage/power.
__________________
2004 Lund 1700 fisherman, powered by Yamaha F80/F8 kicker
Towed by '07 2500hd Chev/Dmax
'09 Arctic Fox 811 Camper
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Prop Question - 20' Lund Fisherman/Yamaha F200 PierBridge Prop Questions and Topics 3 March 29th, 2009 06:07 PM
9.9 Yamaha on a Lund 1700 fisherman drhdres Yamaha & Suzuki Outboards 3 October 7th, 2007 05:19 PM
Prop for Yamaha 60 and Lund Alaskan trout21 Yamaha & Suzuki Outboards 1 January 24th, 2006 05:45 PM
Prop for Yamaha 60 hp 4str on Lund Alaskan trout21 Prop Questions and Topics 2 January 21st, 2006 06:43 AM
18ft Lund 50F Yamaha Prop??? Yukon_Traveler Yamaha & Suzuki Outboards 6 August 1st, 2002 02:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
