I am having trouble giving my engine full throttle. When I am at about 3/4 throttle the engine runs fine. If I go up a little bit it will run pretty well bogging down for a second at inconsistant times. When I put the throttle all the way forward it bogs down and stays that way unless I back off of it. This has gotten worse since i've owned the boat.
I also recently started having trouble off the start. Say I want to pull a skier and give it full throttle from and idle, it kills the engine. It didn't use to do this.
It would be much appreciated to anyone who can help with the troubles that I'm having. Thank you.
