boatingonindiana
- Aug 16, 2009
- 2
I have a 1972 Johnson 25 hp. I am trying to replace the water pump like I have done before on a similar engine. I have unbolten both parts of the lower unit and taken the side plate off in order to get to the linkage. Inside there are two flathead screws. I have loosened both of them and it still does not want to budge. Do i need to take something else off down by the prop. There are 6 screws going into the bottom of the prop and one that goes through the side of the very bottom by the lower unit. I have sprayed the linkage with PBblaster and will let it set over night.
