  #1
Old September 18th, 2009, 10:17 AM
kcseasprite kcseasprite is offline
Default max RPM of 1977 115 mercury and whats final drive ratio?
I need to know what the max rpm is for this motor and the final drive ratio example: 2:1,2.07 etc. Also would like to know max timing for this motor. Thanks.
  #2
Old September 18th, 2009, 10:39 AM
Jeff_G Jeff_G is offline
Default Re: max RPM of 1977 115 mercury and whats final drive ratio?
19-21* 5800 rpm 2 to 1
  #3
Old September 18th, 2009, 05:15 PM
thanks
  #4
Old September 18th, 2009, 05:39 PM
daveswaves's Avatar
daveswaves daveswaves is offline
Quote:
Hi Jeff, my book has the 77 1150 with a max at 5300, the 77 1500 is a max at 5800. From experience, the 77 1150 just cant gulp enough air to make 5800. I know the innards would take it no problem but....
__________________
Mercury inlines....nothing else stacks up
The answer to "do i need to change my water pump impeller" is YES
  #5
Old September 19th, 2009, 03:29 AM
emckelvy emckelvy is online now
5300-5500 is probably a more realistic rpm for an 1150 I reckon. My old 1350, on the other hand, had no problem spinning the tach right up to 6000! Pretty interesting on a 15'-9" Super Sidewinder!!!
Here's all the info you'll need to get your 1150 Tower of Power in perfect tune:
http://forums.iboats.com/showthread.php?t=168855
HTH..........ed
  #6
Old September 19th, 2009, 01:55 PM
I should have expounded more. The 115 was rated for a full throttle of 5300 as Dave correctly pointed out, in the 1970's.
However I found if you prop it for 5800 you will have a much better all around boat. Propping will allow the 5800 no problem.
The 150 I recommend 6,000. The XS was rated for 6300 and I would say leave them there or even a little less, more of the 1500 specs.
In all of these engines lower the timing to around 19* with todays fuels and go up one jet size. Your motor will thank you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
max RPM of 1977 115 mercury and whats final drive ratio? kcseasprite Mercury & Mariner Outboards 0 September 18th, 2009 10:06 AM
whats the right gas to oil ratio for 65hp mercury casper75 Mercury & Mariner Outboards 2 January 1st, 2009 12:06 AM
Anyone know the final ratio of OMC 5.0 outdrive? swsidlo Prop Questions and Topics 0 November 4th, 2005 10:10 AM
Final Gear Ratio 90 HP Evinrude kart33 Johnson & Evinrude Outboards 1 November 15th, 2002 06:22 AM
Final drive ratio and prop speeds/suggestions Skinnywater Honda & Tohatsu/Nissan Outboards 8 August 28th, 2002 04:59 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
