  #1
Old September 18th, 2009, 10:15 AM
iammarcuse iammarcuse is offline
Default Yamaha 130 fouling cylinder #2
I have a 1989 Yamaha 130. It runs perfectly but I keep fouling the #2 spark plug after about 15-20 hours. The plug becomes black and fouls out. So I am guessing that one cylinder is running rich. The pilot screws are all 7/8 out as per manual. The motor blubbers a little at trolling speeds but these high compression motors always do a bit. I have swapped to a NGK BR8HS plug which is one range hotter until I solve the problem.
Any thoughts? Rebuild carb? Reset float? Replace needle valve?
  #2
Old September 20th, 2009, 09:10 AM
Default Re: Yamaha 130 fouling cylinder #2
Anyone have any real-life experience with this? How about you Rodbolt? You've seen it all. Thx kindly.
  #3
Old September 21st, 2009, 05:49 PM
TTT
Anybody?
  #4
Old September 22nd, 2009, 09:27 AM
Doh Doh is offline
I am not a professional, but I do run a 1997 130, and I would suspect.
#1 Swap the well used plug out of 1 of the good Cylinders. New plug foul easier than used ones.
#2 Needle and seat. Maybe not worn but may have the Red needle and seat Sealant stuck in the inlet side.
#3 Slim chance of a weak coil
  #5
Old September 24th, 2009, 01:05 AM
OK, thanks. I found some other posts with the same problem. I am going to spark test it first. Then test check valve on return line and finally clean carbs, set float etc.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
plug fouling on#2 cylinder 1978 35hp copperminer Johnson & Evinrude Outboards 1 September 12th, 2009 06:28 PM
one cylinder fouling plug, other is clean dthrckt Johnson & Evinrude Outboards 1 July 19th, 2009 09:33 PM
top cylinder fouling boggi Johnson & Evinrude Outboards 3 April 26th, 2008 06:19 PM
150HP 1987 #1 Cylinder is Fouling the Plugs HELP woodcutter43 Mercury & Mariner Outboards 4 July 7th, 2007 03:12 PM
Johnson 25hp Fouling One Cylinder gailforce Johnson & Evinrude Outboards 1 June 20th, 2006 03:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
