Volvo 290 sp convert to dp
robjen1019
I was wondering what is involved. Is it a direct replacement, or do I need a special conversion kit. I see volvo sells a kit, but I was planning on just getting a donor boat.
Thanks
jtybt
Re: Volvo 290 sp convert to dp
A friend did it with an older 270. just bolted up...but I would guess a slight matching problem if there's a big difference in years.
billbayliner
The AQ series Duo Prop lower unit will bolt right up. There is some shimming required.
