MaxBaldwin
- Aug 15, 2009
- 2
Hello,
This is my first post so i am a little long winded. Sorry.
I just got my hands on a 1971 Lightwin. The motor is in good shape but i know nothing about it's history. I need a little help in figuring out if i have a heat issue or not. First i ran the motor in my test tank. I shut the motor down after about 3 minutes. i touched the power head and felt it was hot. it was not hot enough you would have got burned. This is a noticeable difference in comparison between my lightwin and a 1954 evinrude 15hp I have that is cold to the touch. When running i did notice that water was spitting out of the 8 little ports. For some reason i thought there should be more and not knowing the history of the motor i checked the water pump condition. I peeked into the housing and everything seemed good.
Today i took it out on the lake. Same thing. The motor seems a little hot in comparison to my other. I ran it this way for a while stopping from time to time to check the motor. If you flicked water at the head you could get it to sizzle (a little) if you hit directly on the head. You could get nothing on the sides of the motor. Water did spit out of the ports. Nothing was blocking the intake. No loss or change in performance. No issue stopping and the restarting. There is no previous signs of heat. ie:discolored paint on the head.
