  #1
Old September 16th, 2009, 02:27 PM
bryanwess2000 bryanwess2000 is offline
Default safe timing on 1977 mercury 850?
I read the link and sync thread and it says 21* max timing but thats
6* less than my manual says and the motor is a dog when set at 21*.
The motor was at 30* before I changed it and has been run this way for >5years. I currently have it set at 25* and it runs ok, just down a little on power. So what is the safe timing on my motor since the link and sync covers all inlines which range from 18*-30* according to my manual? Should I be ok
2* lower than max advance (25* instead of 27*) ?
  #2
Old September 16th, 2009, 11:42 PM
Default Re: safe timing on 1977 mercury 850?
Just read several pages into the link and sync thread and a couple people
had 850's and were told to run 21* so I guess i'm going to have to run it like that and deal with the major power loss. I guess going down to a 19p prop will be in order.
  #3
Old September 17th, 2009, 12:31 AM
corm's Avatar
corm corm is offline
Hi,
I run mine at 27.
If your worried about yours or you live where they sell
that oxygenated fuel you could back it down to 25.
The 4 cyl were not prone to burning pistons like the L6 cyl were.
__________________
This is free internet advice.
Have Fun,
corm
  #4
Old September 17th, 2009, 10:47 AM
Chris1956 Chris1956 is offline
Are you sure that is a 1977? The late 60s mercs used timing specs in the 30s. The 70s mercs used 23* as max timing. Has the timing pointer been verified to be accurate?
  #5
Old September 17th, 2009, 04:23 PM
Not sure if your asking me or corm. I'm pretty sure it's a 1977, it has
the #4596244 on the mounting bracket and the port side of block. According to my research it's a 1977. Plus it has trigger and coil ignition instead of a
distributor. From what i've read this type ignition was only on 1976 and 1977
model 85hp motors. My cover that goes in front of the carbs says 27* ATDC
max advance @ 5500 rpm as does my manual. Also this is an inline 4. I verified
TDC with a dial indicator and a depth micrometer as well as visually when I
pulled the exhaust cover, the pointer was within 1* Atdc and Tdc.
  #6
Old October 9th, 2009, 03:17 AM
trendsetter240 trendsetter240 is offline
Yes, your motor is a 1977. My engine spec sheet also says to set at 27* BTDC. Personally I would set it at 27*.
  #7
Old October 9th, 2009, 03:45 PM
Jeff_G Jeff_G is offline
I would recommend dropping the timing to 25* and going up one main jet size. The problem isn't the engine but the fuel today. All of the inlines I recommend a 2* drop.
You will run fine at 27* until you get that one batch of junk they call gas today.
Timing is a matter of acceleration more than a power issue. You should not notice any difference between 27 and 25* in power, and on a small acceleration lag but only if you run a very light fast boat.
Inline 6 motors called for 23* most run 21* but even racing I usually took my timing all the way down to 19* at WOT.
Also keep in mind on the ADI ignitions your WOT timing will usually be 2* less than at cranking speed.
__________________
You let the factory smoke out of it. All products have smoke installed in them from the factory. You can not purchase this smoke. The problem is, when you let the smoke out of it, the part is ruined and you have to get a new one. I wish I could find a place that sold the factory smoke.
Never argue with an idiot. They drag you down to their level, then beat you with experience.
3 X APBA Formula V Nat'l Champion
APBA Formula V US-1
It took me 29 years to become an overnight success.
  #8
Old October 10th, 2009, 12:48 AM
ouchita ouchita is offline
Mine is a 1976 and i run it at 27 with no problems which is what my manual says also
  #9
Old October 10th, 2009, 10:39 AM
Can you get 1976 quality gas in your area?
__________________
APBA Formula V US-1
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
How much timing is safe? Tolly family Johnson & Evinrude Outboards 0 March 23rd, 2009 04:01 PM
1977 Johnson 35 timing whoteva Johnson & Evinrude Outboards 0 July 12th, 2007 04:45 PM
1977 25hp Johnson timing Bucko250 Johnson & Evinrude Outboards 1 September 4th, 2005 10:22 PM
Timing on a 1977 351W OMC I/O HELP!! Galloping Ghost Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 11 August 11th, 2004 06:16 PM
Timing for 1977 and 1985 70 HP OMC smack Non-Repair Outboard Discussions 2 August 12th, 2001 06:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
