Old_VA_Angler
Thread starter- Joined
- Apr 21, 2009
- 2
I was just checking out my boat today and had the outdrive in the fully up/out position. I noticed from below that my exhaust bellows is not physically connected to the pivot housing assembly, but is attached properly on the engine side with the correct clamp. Is the exhaust bellows supposed to be clamped in some sort of way to the pivot housing so that the out flow of water/exhaust travels down through the upper and lower unit and then out by the prop? I tried to extend the bellows up to the flange on the pivot housing and it appears that its not long enough to reach properly with the outdrive in the fully up position. Makes me think that it was replaced at some point in the past and perhaps they used the wrong length part. Does this represent a significant issue or not?
1987 Bayliner Trophy 24' hardtop
5.0L OMC Cobra
5.0L OMC Cobra
