Chrysler 35 Hp -72 don't engage forward gear
Mr-man
Hello. My engine overheated so I changed the Impellar. But after i re-assembled the shift rod I Can't go forward. Neutral and backward works fine and their positions mach with the remote arm. When i shift to forward It just makes noises from the gears it seems like the rod don't push enough to engage to forward. But when the engine is turned off and i move the prop by hand, the flywheel spins and vice verse, both with forward and backward gears.
I have started the engine with the arm pointing forward, and the boat started to go forward. But from starting the engine i neutral it's impossible I've tried to Adjust the rod on the coupling between upper and lower rod. But when i do that, I can hear clicking noises when i spin the prop in neutral, and the N-mark on the remote control don't match. I also tried to adjust on the wire, and the remote control, but without results. So how should I solve this???
And by the way, when i have backward gear in, and spin the prop should it "block" i both directions, and should it do so with forward to??
