On our last trip out we were towing a tube and then the motor died. I went through the routine checklist and nothing worked. We were able to get a tow and made it home. Later I was doing some diagnostics and found that the fuel pump would not prime just when I turned the key. I pushed the reset on the fuel pump, nothing. Then I pushed it even harder and it clicked. Then I turned the key and the boat started right up. The next day I replaced the fuel filter and the motor started right away. After idling for a minute or so the engine began to seem as if it were straining. I checked the gauges and noticed my RPM's were reading around 3000 (but the engine was not reving as if it were at this RPM) and then the fuel tank gauge went from half a tank to zero. But I know that the tank if at half, no fuel leaks noted. Then I heard a loud whine coming from the rear of the motor, I listened closer and belive it was coming from the second (high pressure) fuel pump. The engine never stalled but the gauges were giving me these very weird readings. I did not know what to think so I shut the motor off and decided to seek help before I started it again.
Any ideas? Please.
Any ideas? Please.
