Folk, hello. I'm very unfamiliar with outboards, I've read through the stickies and searched a bit. Here's my problem, I have a 1980 60HP evinrude. I bought it knowing there was a issue with running. PO had carbs rebuilt. It has a high idle lever.
Symptoms;
It will start and idle all day with muffs in the yard. really no trouble starting it up from cold even after a few days although I do not believe the electric choke is working. I started it at home warmed it up, took it to the local lake about 20 mins I was in the water. Move it over to the dock I she won't start cranking but not even sputtering. So I move the high idle lever all the way up and it finally catches. I also pumped the primer a few times. So it's idling fine still fairly cold. I get it into gear and it stalls and fiddle again and get it going and pull out into the lake and no wake for a while, just as the timing lever move out. Then she stops, after about 10 mins and won't start. So we fish for a while maybe 1/2 hour I try to start again. cranking but no go, again I pump and move the lever trying different combos to get it going and she fires. High idle up, I'm able to bring it down to mid lever but obviously cannot ingage the drive, then it stalls. after fishing again, same thing. I'm able to get it into gear and finally open it up and it has a definite bog/hesitation just as the timing lever moves at higher speed. then it quites and I have not tried again.
So, my first though was incorrect timing. I'll try that tomorrow, but what is a "spark tester" and how do I set it to 7/16" I think I understand the rest.
Any other ideas??
bob
Symptoms;
Any other ideas??
bob
