Re: Force 150 Exhaust Cover
Holy crap I feel like an idiot.
So the starter has a positive terminal and is ground through the engine block.
I didn't realize the washer itself was non conductive, so I put the nut > washer> positive cable on the starter resulting in a short. Hence the reason it never started.
Using my meter I could see once I replaced the solenoid that voltage was going to all the right places, however there was a huge drop once the key was turned, not to mention sparking at the ground terminal of the battery. Figued out that the positive cable shouldnt be touching the starter itself (and on closer inspection neither was the power terminal on the starter) and found that non conductive washer. Put that inbetween the starter and the positive cable, problem solved.
In my defence the seloc manual I have doesnt even show that washer, but I should have seen that when I took the motor apart to replace the gaskets.
Engine fires right up now no problems.
Thanks again for all the help pnw. Free beer if your ever in southeastern mn.
