  #1
Old September 14th, 2009, 12:03 PM
200Horizon 200Horizon is offline
Default Bilge Pump isn't working
Hi everyone! My husband bought a used 1995 200 Horizon at the start of the season. It has been a great boat but the bilge pump has quit working on it. This is our first boat so we are learning about it as things happen. Does anyone know where the bilge pump is located and how to fix it? It worked last weekend when we went out, but yesterday it wouldn't come on at all. Any advice would be greatly appreciated.
  #2
Old September 14th, 2009, 05:01 PM
boat1010's Avatar
boat1010 boat1010 is offline
Default Re: Bilge Pump isn't working
I would think we need a little more info. First of all welcome... How do you know that it isn't working? Most boats don't fill with water very fast. So if you have looked in the bilge and can see water and nothing is coming out of the bilge discharge then you do have a problem. The pumps are generally located in the lower part of the bilge. sort of in front of the motor. Some have a float switch that come on when there is water. When the motor isn't running you should be able to open the engine compartment and hear the pump running.
__________________
"Spend a little money, save a lot of time"
  #3
Old September 14th, 2009, 05:58 PM
When we turned on the bilge pump when we took it out of the water yesterday we didn't hear the pump even try to turn on. There was very little water in there that we could see, but my husband likes to drain it out as much as possible before we leave the marina. Usually when we do this it spits a little water out the sides and you can hear it running, but nothing yesterday.
  #4
Old September 14th, 2009, 06:24 PM
boat1010's Avatar
Most bilge pumps will not get all the water out of the bilge. Most of the people will take out the bilge plug at the back of the boat and drain all the water out. The bilge pump on my boat is very quiet and hard to hear. But you should be able to see it close to the center of the bilge. They are pretty inexpensive to buy and fairly easy to replace.
__________________
  #5
Old September 15th, 2009, 10:17 AM
Dave1251 Dave1251 is offline
Check the fuse first before you change the pump. To find the pump, just follow the tubbing connected to the hru hull where the water comes out. The pump will be just infront of or under the engine. Any size pump will work as long as the outlet of the pump is the same size as the tubbing.
If you do not have an automatic switch (float) on the now, you can add on as part of the new pump.
Also, make sure your wire connections are water tight.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Half of my accessories (including Bilge Pump) not working PLEASE HELP Robertpel9 Electrics, Electronics and Trolling Motors 6 August 27th, 2009 03:44 PM
Bilge pump, Horn and Anchor light not working Only navigation light works inyourwake Electrics, Electronics and Trolling Motors 3 June 7th, 2009 03:09 PM
bilge pump not working torcano Electrics, Electronics and Trolling Motors 4 October 26th, 2008 08:43 AM
Mercruiser 4.3 bilge pump not working rapidrick Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 September 22nd, 2008 11:44 AM
bilge pump not working properly ? slamer12 Boat Topics and Questions (not engine topics) 4 May 25th, 2005 06:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
