No water to Powerhead on a 1973 model 50 hp
blaine76
I just got the motor, the guy I got it from said the water pump stopped pumping and he shut the motor down without over heating it. When he took the foot off and them impeller had come apart. He replaced the impeller and took an air hose and blew through the Pee hose and are flowed, so he put it back together and it does not pump water. I pulled the foot and took a water hose and run water from the Pee hose and water came out the foot around the copper line and a little out the copper line, but I can not get any to flow from the bottom of the foot ( Copper feed tube) to the Pee hose. I have never had any dealings with a Mercury before, and any and all help will be greatly appreciated. Thanks
blaine76
Re: No water to Powerhead on a 1973 model 50 hp
any help at all would be greatly appreciated
crappiejig
First thing I would do is pull water tube out and run something thru it to verify no chunks of impeller are obstructing the tube.If ok remove rear cylinder block cover and inspect water jacket area for pieces of the impeller.You will be surprised at where these pieces can end up,and obstruct flow. Just my thoughts on what I have done in the past.
I am in that same boat the is water coming out when it put the garden hose on the copper feed tube and water coming out of the water put with a drill hooked to it in the tank. When I put it all together and run it no water coming out. Did you find anything or are you still in my boat?????
blaine76
Its been raining, as soon as it clears up I am going to pull the power head and see If I am able to find where it is stopped up at, I am unable to get the copper line off.
