Hello , JUst completed a major repair on my2003 mercruiser 5.7lt 2bcarb thunderbolt ignition lost compresion in #6 and #4 cylinders. had the head redone and found both exaust valve seats burned out pretty bad . i am suspecting that there is a timing issue that caused this damage. the engine is back together with good compression but cant set timming because there are no timming marks on chain cover just a pointer. THe seloc manual metions use of scan tool to set up base timming is this true Is there anyway of setting timing with out it ? i have heard of running boat wot advancing timming untill it pings then turning distributer back a notch .pretty risky though. any help would be apreciated .
