  #1
Old September 12th, 2009, 11:38 PM
jamester jamester is offline
Default Yamaha 2001 150HP oil alarm
Oil alarm problem with my 2001 Yamaha 150HP 2 stroke.
The oil level indicator flashes most of the time even though the main tank up on the engine is full. Then some times it does not flash and shows the tank to be full as it should. When I use up all the oil in the reserve tank, the alarm goes off and the engine goes to low speed just as it is supposed to. This happens whether the indicator is flashing or not. If the indicator is flashing, I must then use the switch on the engine to fill up the reserve tank. Some times I can fix the flashing low oil level signal by simply turning off the engine and restarting it. This does not always work however. The flashing indicator is there most of the time but fixes itself once in a while. We had the level sensor within the main tank changed and this did not help. Any suggestions on how to correct this problem? Has been happening for a number of years with no solution. Bad electrical connection in a connector??? Defective engine computer that fails intermittently?? HELP!!!!
  #2
Old September 13th, 2009, 02:53 AM
seahorse5 seahorse5 is offline
Default Re: Yamaha 2001 150HP oil alarm
Quote:
The sensor and wiring in the remote tank is what controls the red warning light and signals the oil controller circuit so the pump will run and fill the main tank.
  #3
Old September 13th, 2009, 10:31 AM
rodbolt rodbolt is offline
not quite.
while we are at it lets review terminology.
the engine tank has a 3 position switch. float up and sw1 is on and commands a remote tank pump off,float at middle position sw1 is off and sw2 is on commanding remote tank pump on. however on 2.6l v6 motors from 1990 to 95 the trim sender must be working or all pump commands are ignored.
with the engine tank all the way down sw3 is on and commands RPM reduction,audible tone set and a solid red indicate.
now to the switch in the remote tank, its an odd one as its about the only circuit on a yamaha that an open switch,or broken wire, will cause an indicate.
as long as SWB is closed you get a green indicate on the guage,this tells the oil control module the remote tank level is sufficient for oil transfer, when SWB opens the yellow indicate is lit and automatic oil transfer is inhibited but there is enough oil in the remote tank for 2 manual transfers.
now to make the lamps flash normally requires a low engine tank level coupled with SWB in the on position.
now the oil control module sees a problem that should not occur during normal operation, all alarms and RPM reductions still function but the indicators flash instead of solid illumination.you could have a faulty trim sender,a faulty SW1 switch at the engine tank,a clogged filter at the remote or a pinched oil transfer line or a corroded wire somewhere.
so remember SW1,SW2 and SW3 are engine tank switches for pump off,pump on and alarm. the remote tank is SWB and controls green lamp,yellow lamp and inhibit transfer functions.
NO other alarm indicate other than yellow and green are controled by SWB.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
possible false oil alarm '91 150hp vro yamaha danielp6378 Yamaha & Suzuki Outboards 5 July 13th, 2009 07:46 PM
2000 Yamaha 150HP 2stroke alarm sound steilbergs Yamaha & Suzuki Outboards 2 December 28th, 2008 08:48 AM
Yamaha 2001 150HP Tilt/Trim Leaking seatrout13 Yamaha & Suzuki Outboards 2 August 7th, 2007 03:07 AM
2001 150hp johnson macfish Johnson & Evinrude Outboards 1 August 14th, 2006 06:16 PM
DUAL 2001 MERC 150HP OPTIMAX OVERHEATING ALARM jmusick3@cox.net Mercury & Mariner Outboards 1 July 6th, 2006 09:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
