Lion hunter
- Apr 9, 2005
- 1,529
1967 60hp johnson. I bought a entire distributor assy. off ebay becuase I broke my distributor cap. Supposedly the one I bought came off a 1963 75hp. The distributor cap was the same and worked. Question is on the rotor. I know there was different rotor for magneto ignition. The rotor on my 1967 has a blade width of 5/16". The rotor that came on the distributor I just bought is the same. So now I don't know if they both are correct or one of them has the wrong one.
Also does anyone know if the coil resistor wire on a 1967 runs the entire length or just from the key to the motor plug. The White/red wire on mine was shot from the motor plug to the coil.
