Hi all,
I have a wilson flyer (UK) 17ft cathedral hull (tri-hull) day boat which i use for fishing inshore waters of the bristol channel (UK). It has a 55hp Yamaha 2 stroke engine which is fairly old but still runs fine.
The boat itself used to have a inboard engine and a jet drive inside and through its lifetime this has been removed and an outboard has been stuck on the back. which has never been setup correctly and so the engine doesn't perform as it should.
I have tried to fix this problem before but weather conditions and difficulties has stopped me in my tracks so any help would be very appreciated.
when we brought the boat the prop was the wrong size and was just straining the engine. I think it was a 10 1/2 x 17 which under rev'd.
I brought a couple of props last year but like i say haven't really had a chance to try. The current prop is a 11 3/4 x 12 which i brought purely because it was from a 40hp yamaha.
i have brought 2 tacho but cant seem to setup them up properly
The performance with this prop is that it still under rev's.
i think the diameter is too large and i think this could be one cause of the problem.
Being that it is over reving, would you suggest trying a smaller pitch prop.
many thanks in advance and i can give you as much info as possible to help.
