  #1
Old September 12th, 2009, 03:23 PM
trophy91's Avatar
trophy91 trophy91 is offline
Question 2001 150 Mercury jumps when in forward gear
Yesterday when I took my boat out two problems arose. One had to do with the fuel system which made the motor lose power and vibrate the boat the more I advanced the throttle. The other was when I put it in forward gear and started to go forward after about 50 to 100 ft the motor would jump once almost like it was kicking into gear and then it would be fine. I fixed the fuel problem by installing a new separator, filter and a new gas line. It has plenty of power now and no Vibrations. After taking it back out it still has that jump/bump in forward gear but only after going a little ways then it happens. Can anyone give me any ideas? do you think it could be the gears locking into place? If so how do I fix it? Its never happened before until the other day.
  #2
Old September 13th, 2009, 12:26 PM
CharlieB CharlieB is offline
Default Re: 2001 150 Mercury jumps when in forward gear
Two tests
First, with the key OFF< and the lanyard PULLED OFF, shift into Forward gear, and STAND on the left side blade of the prop turning the motor. Does it turn the motor without slipping, clunking, firmly locking into gear?
The problem may not be the gearcase or shift cable adjustment.
Pull the spark plugs and inspect them for carbon accumulation, is there enough one one or more plugs that may be causing it to short or misfire until it 'burns' clear enough to fire for a while?
Replace the spark plugs with new plugs and retest acceleration, if cured, then you should pull the airbox cover and observe the carb throats (NOT running) while you pump the primer bulb, watching for even the slightest amount of fuel flooding in any carb which could cause spark plug fuel fouling at low speeds, yet burn clear and operate acceptably at WOT.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
78 25horse outboard that jumps out of forward gear GoBlue Johnson & Evinrude Outboards 8 June 26th, 2009 08:44 PM
jumps out of gear in forward skippy867 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 April 17th, 2009 08:52 PM
35 hp 84 Evinrude jumps out of forward gear Johntree Johnson & Evinrude Outboards 3 April 6th, 2006 05:03 PM
35 hp 84 Evinrude jumps out of forward gear Johntree Non-Repair Outboard Discussions 1 April 6th, 2006 03:40 PM
68 johnson outboard jumps out of forward gear DEERSLAYER2000 Johnson & Evinrude Outboards 4 June 4th, 2005 09:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
