15 ft Donzi sport jet 90 twisted crankshaft
where can I get a crank shaft straightened I have been trying to get this engine running right for 2 years? A friend suggested stickling a screw driver down the spark plug holes to see where the pistons are. piston one at TDC lines up with 0 mark on the fly wheel more or less off by a MM or 2. Piston 2 about half way up. Piston 3 is at the same point as piston 2 about halfway up.
I may part this boat out if it is to expensive to fix. any one need any parts? the boat has all new electronics.
