mercruiser 165 hp coupler problem
shoegoo183
I blew the top half of my alfa 1 outdrive had it fixed but now the coupler on the back of engine is gone. how hard is it to change the coupler,i was told i need to pull the engine and replace it.Now i have and engine from where i blewout head and was thinking of using the coupler from there it's the same engine, is there a diagram of how to do this,i'm pretty handy in doing this and I just got done rebuilding my carb. Is there anything i need to know before i take off the back part of this coupler.
Thanks
dubs283
Re: mercruiser 165 hp coupler problem
pull the engine
remove bellhousing
remove and replace coupler, use loctite on the bolts/nuts, torque to spec
shoegoo183
Re: mercruiser 165 hp coupler torque specs
Does anyone know the torque specks for when putting in the new coupler.
Thanks
dubs283
its in the manual
download it from the mercruiser manuals section in the adults only sticky
bigskiohio
Master Chief Petty Officer
you wont be able to get a torque wrench on it i dont think,nuts are behind coupler a little. this is what mine looked like yours might be the same.
