  #1
Old September 11th, 2009, 03:06 PM
crabguy crabguy is offline
Red face HELP 1973 evinrude 50hp breacking fly wheel key
hello my name is guy and i found this motor for $100 and they said it ran when i got it home hooked it up and tried to start it and would not start.me and a friend was testing every thing and found that the key that holds the fly wheel in time was sheered so i went to the dealer and got one put it in and it started after 2 crancks and ran like a champ put it on the boat and took it to the lake and it started good winth some ajustments and and ran backed it off the trailer it went into ger hard but still worked put it in gear and started to go got out of the 5mph and started the throghtle up got half way there and the motor raced and then died and would not start again it was tring to but was acting like it was out of time and im perrty shure it is what could have coused this and is it an easy fix?
  #2
Old September 11th, 2009, 03:17 PM
samo_ott's Avatar
samo_ott samo_ott is offline
Default Re: HELP 1973 evinrude 50hp breacking fly wheel key
Did the key break the second time? This usually happens because it was not torqued down enough. I don't know that model but it will probably range from 50-100 ft lbs. Make sure it is to spec or it might shear again.
__________________
Steve.
  #3
Old September 11th, 2009, 03:26 PM
F_R F_R is offline
Unbreakable flywheel rules:
The crank and flywheel tapers must be clean and dry
They must not be damaged. Period. That includes wallowed out key slots.
You MUST use a torque wrench to tighten the nut to specs.
Failure to observe the rules will result in a sheared key at the least, and a destroyed crankshaft and flywheel at the worst. Every time it shears the key, the damage gets worse. After a few times of that and you might as well put it out at the curb for the trash pickup.
  #4
Old September 11th, 2009, 04:36 PM
ezeke ezeke is offline
100 to 105 foot pounds.
  #5
Old September 12th, 2009, 12:03 AM
thank all of you for your help yes the key was sheered but spent most of the afternoon sanding both surfases smooth and we will try it to morrrow i also went and bought a manual and it is 100-105 fps i also canged the oil in the lower unit for good measure im crossing my fingers
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 50hp Evinrude brents Johnson & Evinrude Outboards 4 April 26th, 2009 01:48 PM
1973 evinrude 50hp solidwaste Johnson & Evinrude Outboards 0 July 13th, 2005 05:39 PM
evinrude 1973 50hp adam123 Johnson & Evinrude Outboards 6 March 31st, 2005 02:45 AM
1973 evinrude 50hp Gazzman Johnson & Evinrude Outboards 3 April 24th, 2003 04:05 AM
1973 evinrude 50hp csmithll Johnson & Evinrude Outboards 2 February 26th, 2003 07:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
