Re: Mercury 40hp gear and throttle set up
You need to understand that props provide their "push" going forward. In reverse, the prop runs backwards and they are terribly inefficient. Throttle opening is indeed limited in reverse as well.
Now then -- If the engine seems to go into neutral as you apply more power, it is very probable that you have what is called a spun hub on the prop. The hub of the prop is secured to the blade area of the prob by a rubber cushion. That cushion is bonded to the hub and the blade area. If the bond breaks, the hub simply slips inside the blade area under power. You can check this by placing one mark on the hub and another directly in line with it on the blade area. Run the engine until the slippage occurs. Now see if the two marks are still aligned. If not, the hub has spun. If they are still lined up, something else is wrong.
